Hi
I by mistake disconnect the cable from board . I have a cable with 6 color wires . try to find in manuals the right way to plug the cable .
it will be nice to have how to connect on the other side to the reader connector
Regards Doron
SD Card Cable Orientation
Doron Berezovitz
doronberezovitz1@gmail.com
Re: SD Card Cable Orientation
Which end did you unplug the end going to the Rambo or the end going to the actual card reader?
If it's the end going to the card reader (attached to the lid)... Looking from the front the Red wire goes on the left side. (Keep in mine this is on the old plastic electronic boxes, I'm not sure if it changed on the metal enclosure. )
Edit-Since they changed the website I can''t find the old Kit instructions anymore. but..... You can just see the connector at the top of this picture.
thanks
It is on the other side (the Rambo side ) . I think I have a problem with the interface board . I tried to connect it in the 2 posibble ways . With no success in getting the reader to work. Does any has the electronic scheme of this board ??
Doron Berezovitz
http://reprap.org/wiki/Rambo_v1.3 (I think that's the right version )
Thanks .I meant the sd card interface board and not the Rambo
Doron Berezovitz
- willnewton
