PLA sticking problem
First i start printing normally and while printing the model starts to leave the bed and warping knowing that i use heater of nozzle 225 degrees and bed heater 65 degrees i dont know what is the problem and my software is simplify3d
Re: PLA sticking problem
What are you using for bed adhesion?
no i use the bed heating only
i use the bed heating only i dont use any adhesion
Well if your just trying to print on bare glass... that is your problem. Bare glass only works for a bit and then it will get dirty and the parts will not stick. You can try cleaning the glass but you're better off using some type of adhesion.
For PLA you can try Kapton Tape, Blue Painters Tape, Hairspray, or even Purple Glue stick.
how can i use kapton tape
Kapton tape is just a thin film material (usually yellowish in color) that is applied right to the glass.
yes i have it and i will try to use it now but i dont know how to put it on glass
You can google "How to apply Kapton Tape" and you'll find several methods.
I use the soapy water method... such as seen in this Video.
I just put a drop or two of soap on my hands and wet them and then rub it over the glass, lay the tape on the wet glass, and then squeegee it with a credit card.
Over all.... Kalpon tape works well but it can be a pain to deal with at first and is very easy to tear while removing prints. For PLA I'm still a fan of just using Blue painters tape (3M brand) as it's much easier to work with.
thank you alot about this information and i will try it
