octoprint and reprap graphic controller (the makergear one)
I'm homing in on printing with octoprint. I got a print started and then got a serial error - bad response from printer. I have the graphic controller connected to the RamBo. Is this a mistake, or should I add a switch to the controller to cut off communication with the printer when I'm using the octopi?
Re: octoprint and reprap graphic controller (the makergear o
How are you running OctoPrint?
I have a couple OctoPrint plugins that send info to the LCD so they definitely work together. I'm running a dedicated OctoPi on a Raspberry Pi 3 though.
I too am running a dedicated Pi3. I have it connected to the usb port on the printer. The lcd is connected to the header array inside the printer electronic box and accordingly it's on whenever the printer is on. It could be that my mistake was turning on the bed heater with the LCD and then trying to run a print with the Octopi Pi3. Maybe if I used the octopi to turn on the heater or not touch the lcd after firing up the m2 I wouldn't have any problems.
Does this make sense to you?
I just printed a calibration cube by setting the nozzle and bed temps with the LCD then starting the print via OctoPrint and I didn't have any issues. Is it a consistent error? Maybe a bad USB cable or connection?jferguson wrote:[...]turning on the bed heater with the LCD and then trying to run a print with the Octopi Pi3.
IIRC, the rotary encoder on the display is considered a "slow" input by the firmware so I don't think it could directly cause issues like that.
I'm sure some others will have some opinion.
error happened once which was enough to unnerve me. I'll try another cable. good idea. also another port, there must be some reason that there are four of them on this thing.
SOLVED - or at least discovered.
Problem was intermittent power to raspberry - dicey connector on this particular board. I'll make a chuck to improve stability (reduce wiggleability) of mini usb connector. Case is my design so should be easy.
If "reduce wiggleability" isn't a technical term in accepted engineering fields, it needs to be.jferguson wrote:SOLVED - or at least discovered.Problem was intermittent power to raspberry - dicey connector on this particular board. I'll make a chuck to improve stability (reduce wiggleability) of mini usb connector. Case is my design so should be easy.
Hi Insta. The problem with adopting wiggleability as an engineering term is what would the metrics be? What we're talking about is a a very low frequency partially bounded asynchronous externally perturbed (induced?) oscillation. I wouldn't doubt that there is a word for this in German, maybe even a DIN standard.
Or maybe a quantum function?
