Feed motor
turtleman
Feed motor
Post by turtleman » Sat Dec 01, 2018 1:56 am
I was changing filament and when I tried to start it, it would not feed. I found a piece of the old filament and then tried it again. The motor would not run. Is their a fuse somewhere that I need to change?
Thanks
Re: Feed motor
Post by ednisley » Sat Dec 01, 2018 2:25 pm
The firmware won't drive the motor unless the hot end is at the proper temperature.
Check that first …
turtleman
Re: Feed motor
Post by turtleman » Sun Dec 02, 2018 2:47 am
Thanks, I forgot about that, its working fine now
