M3SE BL Touch Probe Upgrade
The place to discuss the M3-SE
polygonprint
Post by polygonprint » Sat Mar 02, 2019 4:40 am
Hi All,
I have noticed there is a M3 ID probe upgrade kit available from the Makergear store. Will this upgrade work on the M3 SE? If not, I'm a little curious to know why there is no M3 SE kit available? Thanks.
makeal
Re: M3SE BL Touch Probe Upgrade
Post by makeal » Sun Mar 03, 2019 11:41 pm
Someone on the mosaic fb group just bought a M3-SE printer from makergear and it came with the probe attached so it seems that makergear is selling printers with it. Just not sure if its available as a upgrade option. Reach out to makergear and ask them. Mounting plate on ID is different from SE so it might work on SE but you will need to print the belt holder for it
polygonprint
Post by polygonprint » Mon Mar 04, 2019 2:32 am
makeal - appreciate you letting me know about the SE with the probe. I will contact Makergear as suggested.
GlennK
Post by GlennK » Sat Mar 09, 2019 6:02 pm
Tried to find some info about it via Google and failed, could you share a response from Makegear if it is possible?
polygonprint
Post by polygonprint » Sun Mar 10, 2019 9:30 am
Hi Glen,
I did ask about the compatibility of the ID probe upgrade and unfortunately they are not compatible with the SE. However, they are working on a upgrade for the M3 SE Rev0. That's as much information as I was told, so I am not sure what the upgrade will include.
Nycatt
Post by Nycatt » Wed Mar 27, 2019 2:27 am
This sucks. I just received probe upgrade for the SE and it’s a paperweight. I’ll just see it someone wants it on here.
makeal
Post by makeal » Wed Mar 27, 2019 12:48 pm
you just need to get a top plate from SE. ID has a different top plate. Try to return it or you can see if you can find the plate and make it work with SE :)
Nycatt
Post by Nycatt » Wed Mar 27, 2019 1:00 pm
The SE top doesn’t have a mounting area for the sensor.
GlennK
Post by GlennK » Thu Mar 28, 2019 10:28 am
This is sad, thanks for the information
polygonprint
Post by polygonprint » Thu Jul 11, 2019 8:14 am
I'd like to buy one for my M3SE but there's no updates regarding the SE version. Bit disapointing really as it sounded as though it was in the works. I don't know enough to add/modify my M3SE (hardware or software) to take a probe. Has anybody had sucess with adding the ID probe upgrade onto their SE? Cheers.
