Mirror mode? How?
Bioluminous
Mirror mode? How?
I thought I read somewhere that the M3-ID is able to print in mirror mode. I have some parts that would work great in this mode but I can't figure out how to access it. It's different than the duplication mode. Does anyone know how to get this working?
Re: Mirror mode? How?
That sounds more like a slicer setting than a printer feature.
Bioluminous
Yes, it would be a slicer setting. Any idea how to do it?
I don't have a duel but you can mirror a part in s3d and I assume use 1 process one for each hot end . Did a quick google, did not read this but probably will help you.
https://www.simplify3d.com/support/arti ... extruders/
Bioluminous
No, that mode would not allow for simultaneous printing. I'm looking for the feature that switches the printer into mirror mode. There's a code that switches it to duplication mode so that both extruders print the exact same thing simultaneously with the plate divided in half in the y-axis. The mirror mode does the exact same thing, except it just does opposite moves in the x-axis instead of the same. I just can't find any info on it anywhere. It's just a gcode at the beginning.
not sure I understand this but google found this post hear on the forum
viewtopic.php?t=6567
At least for the Marlin X2 variant, M322 may do what you want:
https://reprap.org/wiki/Marlin_X2_firmware
Whether it matches the hardware & firmware you have on hand is an entirely different question … [grin]
It's a bit down the page:
https://duckduckgo.com/?t=ffab&q=reprap+mirror+mode
Caveat: I have zero practical knowledge.
