Hi. So far I have only used PLA on my M2. Can anyone recommend a good filament that maintains its strength in high heat outdoors (direct sunlight, hot climate) that doesn't need a heated enclosure to print? I occasionally need to print items intended for outdoor use and it can get extremely hot where I live.
I thought I had my mind made up on Polymax PC or Prusament PC Blend, until I learned that a heated enclosure is more or less necessary for proper layer adhesion and strength. I've also read that PETG is only marginally better at heat resistance than PLA.
I mainly just print little things for around the house, and I don't have a workshop or even a dedicated space for my printer at the moment, so an enclosure is out of the question for the time being. And I don't think Makergear offers a premade kit enclosure or anything either, which is unfortunate.
Something easy to work with like PLA, but with better heat resistance would be ideal. Any suggestions are appreciated. Thanks!
Filament suggestions for outdoor use, that doesn't need a heated print enclosure?
Re: Filament suggestions for outdoor use, that doesn't need a heated print enclosure?
PETG is much better than PLA for heat and it is a bit more flexible without breaking. I have surveillance camera mounts I designed, which are outside in full sun, east coast summer/winter, going on 4 years now, no issue.
PETG is also UV resistant. I've used PETG for some fence brackets, and they've held up just fine.
theboz1419
I too recommend PETG. Its all I use, now. Esun works really good. There is a simplify3d file for Esun PETg on the forums I use to print.
Would you mind giving us the link? I have my own S3D file, but would like to compare. There is a thread here for sharing those files, but it has been so long, I have forgotten. Insta's something-or-other?theboz1419 wrote: ↑Sun Aug 28, 2022 11:55 amThere is a simplify3d file for Esun PETg on the forums I use to print.
theboz1419
viewtopic.php?t=2593Phil wrote: ↑Wed Aug 31, 2022 4:58 pmWould you mind giving us the link? I have my own S3D file, but would like to compare. There is a thread here for sharing those files, but it has been so long, I have forgotten. Insta's something-or-other?theboz1419 wrote: ↑Sun Aug 28, 2022 11:55 amThere is a simplify3d file for Esun PETg on the forums I use to print.
Better late then never, lol. Sorry just saw this today..
