laywood - d3
laywood - d3
Can the M2 print the laywood-D3 filament?
Re: laywood - d3
In general yes. For the material, it would be good to use a wider nozzle than the standard 0.35mm, so >=0.50mm.
Moreover, laywood is very brittle - so I had problems feeding it via the standard ptfe tube. It sometimes just broke. So I positioned the spool above the printer and fed the filament directly to the print head which worked fine.
