This years Valentines Gift
Mike Hunter
Post by Mike Hunter » Mon Feb 02, 2015 7:51 pm
I've decided to print the Eifel Tower (http://www.thingiverse.com/thing:32825) for my wife. It will test the M2, and me. I did have to scale the downloaded files 200% in order to get the handrail balusters to print (section #2). That section is in the printer now and will tell me how to adjust the other 3 sections. My fingers are crossed.
Mike H.
Mike Hunter
Re: This years Valentines Gift
Post by Mike Hunter » Mon Feb 02, 2015 11:18 pm
The first run of Section #2
Well the first run has been canceled after seeing this stringy mess at the handrail layers. Up till this the print looked excellent with good quality at the bottom. Some time with the eye loupe will hopefully give me a better understanding of the problem. I had a sneaky suspicion this section would be troublesome. Time to search the web for clues ...
Mike H.
Post by jimc » Tue Feb 03, 2015 1:02 am
haha good luck mike. if you enlarged it to maybe 18" tall then split it into pieces it would work out easier. some of that stuff is just too small
Mike Hunter
Post by Mike Hunter » Wed Feb 04, 2015 3:22 am
It looks like I'm closing in on the proper parameters to print this project.
Section #2 completed
There will be a lot of clean-up after all 4 pieces are printed, but it finished and that's encouraging.
Mike H.
Mike Hunter
Post by Mike Hunter » Fri Feb 06, 2015 3:52 am
Levels 1 and 3 are complete, less hand finishing. I ended up using a 2.25X scale factor to get all but the smallest details to print. Assuming I get through the top level, the assembly should be complete tomorrow night.
Level 1 - The Base
Level 3
Mike H.
Post by jimc » Fri Feb 06, 2015 4:51 am
man nice deal mike.
Post by insta » Fri Feb 06, 2015 6:41 am
MakerGear might want to use your prints as some customer-sample photos if you'll let them.
Post by Jules » Fri Feb 06, 2015 2:04 pm
That's incredible! :D (Bet she loves it.)
Just out of curiosity - what do you do with the unwanted bits from bad prints? Any way to reuse them? Turn them into ABS juice?
Mike Hunter
Post by Mike Hunter » Fri Feb 06, 2015 5:59 pm
THANKS everyone.
Jules - I usually throw them out or use them as examples of what not to do. This project is printed with PLA as I heard from others (on ThingiVerse) that they were unable to print using ABS.
insta - Once the project is finished, I'll send a sample photo to MakerGear and if they are interested, more detailed photos they can use. THANKS for the suggestion.
Level 2 finished up earlier this morning, so it's on the the top level. My fingers are crossed.
Mike H.
Post by insta » Fri Feb 06, 2015 6:31 pm
Jules wrote:Just out of curiosity - what do you do with the unwanted bits from bad prints? Any way to reuse them? Turn them into ABS juice?
You eventually stop caring about the bad prints. It takes about a year before you give up on recycling them.
