safety razor
safety razor
Post by jsc » Sat Feb 14, 2015 9:58 pm
My friend Rob (rsilvers, of S3D profile settings and filament drive fame) has been using his microscope adapter to take close up photos of a safety razor and model it precisely. I printed it in PLA at 0.10mm layer height:
Check out that printed M5 thread:
With handle and blade, ready for a test shave:
Dale Reed
Re: safety razor
Post by Dale Reed » Sun Feb 15, 2015 10:38 pm
Jin,
Very nice! However, I've had my beard so long (since late 1980s) that I would hack my face to shreds with that (or any other razor!). Reminds me of an old comedy bit --- "Little --- tiny --- hairs! Growin' out my face!"
sprior
Re: safety razor
Post by sprior » Sun Feb 15, 2015 11:48 pm
Is there any discussion of how he's using these photos to model the razor? Is he using the focus of the microscope to determine the Z dimension?
Re: safety razor
Post by jsc » Mon Feb 16, 2015 12:59 am
Just profile shots to get accurate dimension measurements. Hard to do that with calipers on a small object.
Re: safety razor
Post by jsc » Tue Feb 17, 2015 10:10 am
Some more playing around with finishing. Sanded, then brushed with IPA Weld-On #4. Smooth to the touch where the layers are more vertical, but as it rounds out it gets harder to smooth without pitting. Also, the sanding appears to have bleached out the PLA somehow.
jdacal
Re: safety razor
Post by jdacal » Tue Feb 17, 2015 3:41 pm
Nice job!
jdacal
Re: safety razor
Post by jsc » Tue Feb 17, 2015 8:26 pm
Does anyone know why sanding would bleach the color? I thought the pigment was imbedded throughout the plastic.
Re: safety razor
Post by insta » Tue Feb 17, 2015 8:29 pm
jsc wrote:Does anyone know why sanding would bleach the color? I thought the pigment was imbedded throughout the plastic.
You're creating little air pockets when you sand. The air pockets scatter the light before the pigment can do its job. Sand with a finer sandpaper and re-smooth with IPS #4.
Re: safety razor
Post by jsc » Tue Feb 17, 2015 8:45 pm
I went from 220 to 1000, that's not enough? I grew tired of sanding. Maybe I will try epoxy.
Re: safety razor
Post by insta » Tue Feb 17, 2015 8:46 pm
1000 should be plenty. Epoxy or IPS #4 should do the trick then. Maybe just try smoothing it again?
