Dual Extruder Upgrade - Limited Availability
Re: Dual Extruder Upgrade - Limited Availability
Post by insta » Mon Jan 19, 2015 4:45 am
sprior wrote:As one of the initial dual upgrades I got the left extruder PTFE and the right all metal. I had problems with the all metal nozzle clogging when trying dual extruder prints in PLA. Didn't have the same problem with ABS. I've now switched to all PTFE, but haven't retried the PLA experiment to see if it made a difference.
What I've heard is that with all metal the hot zone is larger and in most cases it's desireable to keep it all small as possible - the PTFE helps keep the hot zone small. Since PTFE is OK with most of the materials we print with these days I'd say it's the easy answer and all metal is useful for people who want to try high temp exotic materials.
PTFE is night and day difference with PLA... the parts are gorgeous.
I use the all-metal one with ABS, and it seems fine.
rpollack
Post by rpollack » Mon Feb 16, 2015 5:03 pm
The dual v4 upgrade kit should be shipping in 4-6 weeks.
The single v4 upgrades are now shipping in batches.
Rick
jeffpowell101
Post by jeffpowell101 » Wed Feb 25, 2015 2:17 am
Rick,
When will these be available for purchase?
Levi8than
Post by Levi8than » Wed Feb 25, 2015 2:26 am
jeffpowell101 wrote:Rick,
http://www.makergear.com/products/m2-upgrades
jeffpowell101
Post by jeffpowell101 » Wed Feb 25, 2015 3:13 am
Thanks! So the difference between the V4 and V3b is that the V4 will just allow higher temperatures?
Post by jimc » Wed Feb 25, 2015 3:30 am
That and the hot zone will be shorter and sharper for better filament control.
rpollack
Post by rpollack » Wed Feb 25, 2015 5:37 am
The v4 does not use any PEEK, is easier to disassemble and clean, works with a range of materials, can be used at higher temps, has a metal mount, is smaller, more manufacturing friendly, easier to assemble, among other things...
Dale Reed
Post by Dale Reed » Thu Feb 26, 2015 9:07 pm
i.e., "It's more better."
mharter
Post by mharter » Fri Feb 27, 2015 12:40 pm
Just completed the order for my V4 dual extruder upgrade! Super excited! Now the hardest part is the wait, but MakerGear has proven time and again that the wait is completely worth it!
askernas
Post by askernas » Tue Mar 03, 2015 11:01 am
Any idea when the single v4 to dual v4 extruder kit will be ready?
I have loved my v4 extruder, and since I just started printing in rubber and flexible materials, this is REALLY where I see a big use for dual extruders.. flexible AND rigid in the same part.. *mmmm*
