Yeah, i thought that i was out of the capabilities of the printer ,ill try slicing it with a thiner layer , if that doesnt work , well i just have to keep it as a computer model for now. It was for a class project presentation. I think its too thin at x pattern, anyways i appreciate all the help.jsc wrote:The regions where the walls cross in an X pattern, they look thin. Are you sure they are thick enough in every layer to fit your filament thickness?
Try slicing at a ludicrously thin layer height with an unprintable filament thickness, like .1mm each, to see if that works.
Then try using a different slicer with your same settings, to see if it is a slicer issue.
Also, your design may or may not turn out to be printable; some of those overhangs look pretty severe.
