Extrusion Multiplier and Extrusion Width
Mount PrintMore
Re: Extrusion Multiplier and Extrusion Width
Post by Mount PrintMore » Wed Jan 21, 2015 12:13 am
jsc - yes, I always select all and continuous (I've never tried the sequential).
In this example, all 4 parts print. The part that was defined by the first process comes out as you would expect, say with walls that are around 0.44 mm thick. The others come out with much thicker walls, some over 1 mm. The only difference between them is in the unique process that was defined the EM was bumped up 4%.
If I create separate files and print the parts one at a time with the exact same process settings, they print fine.
I've actually run into this before with other calibration parts, but never really sorted out what I was looking at.
Post by jimc » Wed Jan 21, 2015 12:36 am
It would be interesting to look at the gcode and see the difference in the extrusion
Mount PrintMore
Post by Mount PrintMore » Wed Jan 21, 2015 2:11 pm
Here's the gcode.
SingleWall.zip
factory file and gcode
(178.01 KiB) Downloaded 746 times
