Show me your sub-100 micron prints!
Re: Show me your sub-100 micron prints!
Post by jimc » Sat Mar 21, 2015 1:06 pm
Well your not going to avoid ringing 100%. With the m2 you can lower the accelleraion and travel speeds so that can be kept to a minimum. I have some parts here printed on a stratasys dimension and even those have ringing. What is in your picture though does seem a bit excessive
mitchfx
Post by mitchfx » Sat Mar 21, 2015 4:00 pm
Yeah, I don't expect to eliminate ringing with the M2, just hoping I can reduce it vs my current printer. Here is a screengrab of the model. You can see there are some prominent wrinkles along the cheeks, but obviously the print has ringing issues as well.
Post by insta » Sat Mar 21, 2015 10:15 pm
Post that STL (zip it to attach) and then say you don't think the M2 can print it well. You'll get about 17 people trying ;) (Cunningham's law)
Post by Jules » Sat Mar 21, 2015 11:25 pm
Chuckle! Okay, I've got to ask....What is "Cunningham's Law"? Anything like Murphy's?
Post by insta » Sun Mar 22, 2015 3:14 am
Cunningham's Law states "the best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer."
Post by Jules » Sun Mar 22, 2015 3:49 am
insta wrote:Cunningham's Law states "the best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer."
ROFL! That is brilliant! (And very true!) :lol:
rsilvers
Post by rsilvers » Mon Apr 06, 2015 1:55 am
When I first got a printer was into low layer heights, but now the lines don't bother me unless they are misaligned. I have come to feel that a quality print is one with uniformity rather than small layers. Besides, you are limited in the other axis to extrusion width, which is generally 0.40 to 0.50mm. As JimC said - my "high quality" prints are generally 0.15mm layers. It doesn't seem to pay to go below that except for really small things - like if I wanted to print a ring.
I am even interested in getting a Volcano so that I can get a 0.8mm nozzle (they make up to 1.2mm) and print 1mm wide and then use 0.6mm layers. The only thing stopping me from doing that is that I just have one good printer.
Post by insta » Mon Apr 06, 2015 5:14 am
rsilvers wrote:When I first got a printer was into low layer heights, but now the lines don't bother me unless they are misaligned. I have come to feel that a quality print is one with uniformity rather than small layers. Besides, you are limited in the other axis to extrusion width, which is generally 0.40 to 0.50mm. As JimC said - my "high quality" prints are generally 0.15mm layers. It doesn't seem to pay to go below that except for really small things - like if I wanted to print a ring.
Re: volcano: The V3b will do 0.75mm handily. It oozes like a mug but ... you kinda knew that going in :)
Slipshine
Post by Slipshine » Wed Apr 22, 2015 7:49 pm
This was a test cube I was working on in the 100 micron arena.
TEST CUBE
Post by insta » Wed Apr 22, 2015 11:54 pm
I'll play, here's some 0.08 on old Ultimachine PLA
(371.02 KiB) Downloaded 341 times
