sudden drop in table during print
Amorese128
SD card reader
Post by Amorese128 » Sun Oct 04, 2015 2:30 pm
This is the error I get on card reader , can this be the issue with table dropping. (echo:SD init fail)
Matt_Sharkey
Re: sudden drop in table during print
Post by Matt_Sharkey » Sun Oct 04, 2015 2:46 pm
What Software are you using to access/control the printer?
Do you have the correct firmware on your new motherboard?
Do you have the correct drivers installed on your computer?
Do you have the V4 hot end?
Post a .FFF file so we can rule out any GCode issues.
Matt_Sharkey
Re: SD card reader
Post by Matt_Sharkey » Sun Oct 04, 2015 2:47 pm
Amorese128 wrote:This is the error I get on card reader , can this be the issue with table dropping. (echo:SD init fail)
those should not be connected, the printer can operate without the SD reader
Amorese128
Post by Amorese128 » Sun Oct 04, 2015 2:53 pm
Matt I am using Pronterface to access the printer.
What firmware do I need?
What drivers do I need?
I am relatively new to this so this is a foreign to me.
V$ hot end???
Matt_Sharkey
Post by Matt_Sharkey » Sun Oct 04, 2015 2:57 pm
Do you have your original equipment? put your original RAMBO motherboard back in with the original SD card reader. At risk of coming off as a jerk, I don't think you're in a position to call a Motherboard "bad", if you don't know what firmware or drivers to use.
The V4 refers to the extruder's hot side, as opposed to the V3B
V4:
V3 and V3B:
Drivers:
RAMBo_USBdriver (1).zip
RAMBO Drivers
(5.16 KiB) Downloaded 504 times
Are you using Slic3r or Simplify 3D for your model slicing?
I want to look at your configurations, so please zip up and post your .ini or .fff (respectively)
Re: sd card reader
Post by Jules » Sun Oct 04, 2015 4:02 pm
Amorese128 wrote:Can someone also answer why I cannot print from my SD card. My M2 is not recognizing the card and I get a error issue. There are files on the card because when I place it in my computer the files are there. When placed in the M2 they are gone.
There are limits and specific rules to naming the files before the software can see them:
Maximum of 8 characters in the file name, and no spaces.
The file type has to end in ".g"
(So shorten the name of "Candy_Cane_Car.gcode" to "CanCCar.g" )
