Printing with my new spool holder.
jdacal
Re: Printing with my new spool holder.
Post by jdacal » Fri Oct 31, 2014 6:01 am
Ok, I have good news and bad news. It seems to be working great! The bad news is you can't use the original spool holder with the mount as I modified it, so if you want to use it you'd have to print both pieces. Also the nylon washers I used are optional I included to reduce wear from the parts rubbing against each other.
It was made per creative commons license based on this design: http://www.thingiverse.com/thing:119488
This is the link to the REMIX: http://www.thingiverse.com/thing:523415
jdacal
markb
Post by markb » Mon Nov 03, 2014 2:35 pm
I just got back from a short vacation. I will be printing this up this week.
Thanks for posting it.
Mark
markb
Post by markb » Wed Nov 05, 2014 6:44 pm
Your remake is famous
http://pushplastic.com/collections/3-kg ... c3c2fbdf18
jdacal wrote:Ok, I have good news and bad news. It seems to be working great! The bad news is you can't use the original spool holder with the mount as I modified it, so if you want to use it you'd have to print both pieces. Also the nylon washers I used are optional I included to reduce wear from the parts rubbing against each other.
jdacal
Post by jdacal » Wed Nov 05, 2014 7:03 pm
LOL! Thanks Mark :)
Edit: Wow that's a pretty heavy reel, 6.6 lb. Might have to load test this thing.
jdacal
jdacal
Post by jdacal » Sun Nov 09, 2014 3:01 am
Hey Markb, if you haven't printed it yet, might want to hold off on it. I'm making a change to it so that it can take some spool adapters I'm re-mixing. I'm going to have to add a groove to it.
jdacal
markb
Post by markb » Sun Nov 09, 2014 3:46 am
I was going to print it tomorrow but I will hold off for the new changes.
jdacal
Post by jdacal » Sun Nov 09, 2014 3:47 am
I'll probably post the updates tomorrow. I'm printing it now, just waiting to confirm everything fits together ok.
jdacal
jdacal
Post by jdacal » Mon Nov 10, 2014 12:47 am
Ok markb its ready. If you decide to print the spool adapters you'll need to wire brush the interior diameter a little so they go on tight but not too tight. I'd still put a clip on the spool holder just in case they loosen up after some use.
I'll add more adapters as I run into the various sizes. I have an idea for an attachment for the small taulman holes. Whenever I buy my first Taulman I'll make it.
Includes spool holder mount, spool holder, spool holder 52mm adapters, and clips
M2 Spool Holder Kit Ver 1.2.jpg (132.69 KiB) Viewed 17451 times
The 52mm Spool adapters can slide in the groove for different width reels.
2014-11-09 18.11.37_1.jpg (172.24 KiB) Viewed 17451 times
Show here with a narrower reel...
2014-11-09 18.12.48_1.jpg (159.59 KiB) Viewed 17451 times
...and here with a wider reel
2014-11-09 18.15.07_1.jpg (170.72 KiB) Viewed 17451 times
jdacal
jdacal
Post by jdacal » Tue Mar 03, 2015 8:22 am
I added this new adapter for the spool holder to Thingiverse today:
http://www.thingiverse.com/thing:706365
This is an adapter for the Taulman3D Spools. Lets you use the spool without having to remove the large spool adapter.
Taulman Adapter.jpg (59.7 KiB) Viewed 17191 times
jdacal
