Patent Pending
Re: Patent Pending
Post by jimc » Wed Jan 28, 2015 11:14 pm
yeah there is a minimum order on the guts so i have to buy a certain amt. i usually get 60-80 at a time. thats what you have to do with any product. there is always that up front initial investment you need to cover. there is always a little bit of risk when producing anything. every batch of these i do i say it will be my last one but then they sell faster than the batch before so i just end up doing another one lol. i am running parts for a new batch now actually. 1/2 doz rolls of pet. i run through a roll every 2.5 days running 24 hrs a day. of course i am at a stand stll now since i snapped the heat break on my hot end :(
Capt. John
Re: Patent Pending
Post by Capt. John » Sun Feb 01, 2015 4:27 am
Manufacturing parts using 3D printer can work, as long as the part
is not subject to a lot of stress. My spoons can lift more then 55 pounds of lead.
No 3D part, the same thickness can match injection molding strength of polycarb.
Spoon are .077" thick and even where the snap dug into the eyelet,
only a small indentation was noticeable.
This is polycarb under abuse.
I make 3D printed diver rings, done about 400 of them, but this part is not under a lot stress.
Capt. John
Manistee, Michigan
Reel Amateur at 3D printing
http://www.michiganangler.com
Capt. John
Re: Patent Pending
Post by Capt. John » Thu Apr 23, 2015 1:08 am
M2 perfecting my spoon project is paying dividends in fish caught.
Here's a recent goodie for Manistee, MI, a 36" Lake Trout:
Been very busy with production and miss not being able to read all posts.
Capt. John
Manistee, Michigan
Re: Patent Pending
Post by Jules » Thu Apr 23, 2015 1:18 am
Yeah, that's a keeper! :lol: (Might have to look into one of those gizmos for the hubs - he's a biggggggg fisherman.)
hybridprinter
Re: Patent Pending
Post by hybridprinter » Sat Feb 11, 2017 10:28 pm
Hi Captain John, did you ever convert to a utility patent? If so, what patent service did you use and what was the approximate cost of the entire utility patent process?
Phil
Re: Patent Pending
Post by Phil » Tue Feb 14, 2017 9:40 pm
pyronaught wrote:Put off those provisional patents as long as you can, since once you do it the clock is ticking and you know how fast a year can go by.
Do not put it off too long. As I understand patent law, since the day you published this, you only have a year to file for the real thing.
pyronaught
Re: Patent Pending
Post by pyronaught » Thu Mar 02, 2017 6:10 am
That's true, once you put it online you have the same one year deadline as if you filed a provisional patent. After that, its fair game for anyone to steal your idea. The patent system switched from a first-to-invent to a first-to-file some years back, so it no longer matters if you came up with an idea before someone else did, the first one to file the patent gets it.
hybridprinter
Re: Patent Pending
Post by hybridprinter » Sun Mar 05, 2017 12:59 am
How about if a provisional patent expires without converting to a utility patent? Does first to file still apply?
Phil
Re: Patent Pending
Post by Phil » Sun Mar 05, 2017 4:00 pm
hybridprinter wrote:How about if a provisional patent expires without converting to a utility patent? Does first to file still apply?
Nope. The idea would then be in the public domain, so nobody can patent it.
Re: Patent Pending
Post by ednisley » Sun Mar 05, 2017 6:02 pm
Phil wrote:The idea would then be in the public domain, so nobody can patent it.
Unless, of course, you have a department of patent attorneys on hot standby:
http://www.theinquirer.net/inquirer/new ... ecause-ffs
AFAICT, owning a patent gives you the opportunity to spend money on lawyers to enforce that patent. If the infringer has deeper pockets than you or resides in a regime with slack IP protection, which will be true for any non-trivial infringer, then owning the patent doesn't have any real effect on your business trajectory.
