ABS vs PET
Re: ABS vs PET
Be very, very careful taking it that hot again! The V3b uses PEEK plastic structurally, and PEEK softens above about 250C. The pressure from the extruder can push the brass core out and permanently ruin the hotend if you go too hot.
- pyronaught
Re: ABS vs PET
Damn, thanks for the fast response... I was just about to go 265insta wrote:Be very, very careful taking it that hot again! The V3b uses PEEK plastic structurally, and PEEK softens above about 250C. The pressure from the extruder can push the brass core out and permanently ruin the hotend if you go too hot.
So what is the best hot end to use for these higher temps?
How about this one: http://www.smw3d.com/e3d-hotend-v6-1-75mm/
Re: ABS vs PET
thats the one i use so you can go that route or the makergear v4.
- pyronaught
Re: ABS vs PET
I tried looking for the v4 on the makergear site but didn't see it listed in the hot end product list.jimc wrote:thats the one i use so you can go that route or the makergear v4.
So for a 24v M2, is the fan 12v and the heating element 24v or are they both 24v? I don't want to borrow pieces from my original v3b hot end, I want to keep it around as a complete working backup.
Re: ABS vs PET
Makergear has a hidden upgrade page. I dont have the link at the moment. It uses a 12 extruder fan and a 24v heater cartridge.
Re: ABS vs PET
- pyronaught
Re: ABS vs PET
jimc wrote:Makergear has a hidden upgrade page. I dont have the link at the moment. It uses a 12 extruder fan and a 24v heater cartridge.
I'll just go with the v6 and use those mounting parts you made for it. Even on the makergear hidden page there just isn't any info about the v4-- not even a picture. I can find loads of info and feedback on the v6 as well as assembly videos.
Re: ABS vs PET
Either way you decide you cant really go wrong. The v6 is a good proven design good to 300c. Its a quality piece that i have had no trouble with. When you get all setup just let me know and ill give you all my profiles.
- pyronaught
Re: ABS vs PET
ednisley wrote:Looks like you definitely needed a miracle for those, then figured out how to get one.pyronaught wrote:so they need to be fast and easy
3D printing FTW!
I think in this case the miracle was that I didn't melt down my PEEK tube printing at 260 for several hours straight. I got all the v6 parts to do this right now though.
I guess in reference to the original topic of this thread, the ABS vs PET debate has to take into account that you would need to upgrade your hot end to get strong PET prints. With the stock M2 hot end, ABS is going to be the winner because you won't be able to print PET hot enough to get strong layer bonding.
Re: ABS vs PET
245-255 for pet. No need to go higer than that. Those temps are within the v3b range. The pet+ your having trouble with wont layer bond well no matter how high you go. I printed that at 285 and saw no difference. Its just the nature of the beast with that stuff. I personally think on the opaques they use too much colorant or something. None of the other brands behave like that.
