Poor horizontal-supported surfaces.
CCVirginia
Re: Poor horizontal-supported surfaces.
Post by CCVirginia » Fri Aug 28, 2015 4:50 am
jsc wrote:Zip up your factory file and attach it so I can see what you're doing differently.
I noted that concentric Vs rectilinear made a difference, that may be what we are seeing.
raptor_reloaded_gauntlet.zip
Factory file
(208.13 KiB) Downloaded 579 times
Post by jsc » Fri Aug 28, 2015 6:35 am
Yes, that is the difference. You have concentric top infill. I would use rectilinear with this model.
Also, your support density is 10% except for the top 3 layers. I don't know if 3 layers is enough to recover from that low a density. If you look at the gcode preview, you will see that it's trying valiantly to place the dense layers over basically nothing. Bring that up to 20%, even 30%, or use more dense layers.
