Hardened steel nozzle
Re: Hardened steel nozzle
and this one is the overhang (i dont know why is rotated 90degree remember to flit it)
TEMP_OVERHANG.stl- (562.26 KiB) Downloaded 1288 times
Gcode would be great. Thanks for the STL.
cheers,
c
cheers,
c
i noticed the gcode one is in the office on the printing laptop i will post it tomorrow
first gcode file
first gcode file
TEST_1.gcode- (716.12 KiB) Downloaded 1275 times
second gcode file
speed is my usual slow one so first one take 1 hour second one 1 hour and half
TEST_2.gcode- (1.22 MiB) Downloaded 1296 times
Jules,Jules wrote:Nope. 215 is too high for PLA with a V4. You'll get best results with the 200-205 degree range. (Experience.)
you're right, I'm getting slightly better print quality at 205 and the support material breaks-off comically easily. It wasn't bad before, but this is ridiculous (in a good way). I did notice that small islands can break loose on the first layer at 205, such as the rings around screw holes. I'm running a PEI bed at 60 for PLA. For now I'm running a 215 first layer and then dropping to 205 at layer 2, seems to work really well. I'm sure I could get-by at 205 for the whole thing if I raise my bed temp, but my nozzle heats a lot faster than my bed and I print a lot of parts.
Thanks for the help.
cheers,
c
If small islands are not adhering well. A couple of things that can help are lowering first layer print speed. Make sure your first layer has sufficient squish. And print a thicker first layer. I print pla at 180.
MagicEngineer
For anyone interested, ordering the regular nozzle and specifying in the notes that I wanted the stainless steel one worked fine. Thank you Makergear.
