Intractable bed adhesion issues
Re: Intractable bed adhesion issues
Post by insta » Sat Mar 19, 2016 4:09 am
ednisley wrote:
dramsey wrote:The solution consisted of fixing everything ...
Now, if we could just convince everybody to use those squares as a confirmation test, we'd be set: until you can print simple squares correctly, you can't print anything else correctly, so don't even try.
I wish we could make people do this before posting for help
jason3w
Post by jason3w » Thu Sep 05, 2019 5:17 am
How do i print these? Just add 4 square objects to the tray, one in each corner?
Post by ednisley » Fri Sep 06, 2019 6:57 pm
Here's the process I still use:
https://softsolder.com/2016/04/05/thinw ... libration/
You don't need to use my OpenSCAD source code to generate the models, but you must know the dimensions of your models, however you generate them.
Printing one thinwall (single- or maybe triple- thread) square in the middle of the platform, you can set and verify all the key slicing and mechanical parameters. It will require a few iterations, but it's always much faster than trying to diagnose why a complex part has failed.
With those parameters set, print five identical squares (center and corners) to set & verify proper platform alignment. Again, this may require a few iterations, but you're measuring the actual platform alignment under actual printing conditions, not trying to extrapolate from dial indicator readings.
Once you work through the process, it doesn't take much time at all to verify that the whole software + firmware + hardware stack produces the right result. When you change something (or something changes all by itself), a few squares will help identify what's wrong.
You should also use the squares to calibrate the Extrusion Multiplier for each type of filament.
Post by airscapes » Fri Sep 06, 2019 7:08 pm
ED! You da man!
Jason, see this thread, I just posted what you would need.
viewtopic.php?f=7&t=7591
