simplify3d v3.0
Re: simplify3d v3.0
Post by jimc » Wed Jul 01, 2015 4:13 am
odd. i changed the layer height and sliced it atleast 10 times and it was perfect every time.
jules if you dont mind im going to send the factory file to someone at s3d
Re: simplify3d v3.0
Post by Jules » Wed Jul 01, 2015 4:30 am
Nope, don't mind. I think my version must have been corrupted somehow. (between that and the mandala thing, it had to be something in my version that everyone else wasn't seeing.)
Re: simplify3d v3.0
Post by jimc » Wed Jul 01, 2015 4:33 am
it looks good in netfabb but s3d says there are self intersecting triangles. i tried to upload it to the netfabb azure cloud repair thing and it just fails and gives and error every time. there is something up with that model. not sure what it is.
Re: simplify3d v3.0
Post by Jules » Wed Jul 01, 2015 4:36 am
How would one go about finding self-intersecting triangles in a model?
Re: simplify3d v3.0
Post by jimc » Wed Jul 01, 2015 4:42 am
oh there we go. i put the model in netfabb and just ran a repair sequence on it anyway and it did find some errors on some edges. i opened up the repaired model using your fff that was having issues and it slices great. here is the file. try it out on your end and see if you get the error. fyi you dont have to uninstall other versions of s3d. you can have multiple versions on you machine that will all run.
Bridging (repaired).stl.zip
(188.13 KiB) Downloaded 576 times
Re: simplify3d v3.0
Post by Jules » Wed Jul 01, 2015 4:52 am
jimc wrote:oh there we go. i put the model in netfabb and just ran a repair sequence on it anyway and it did find some errors on some edges. i opened up the repaired model using your fff that was having issues and it slices great. here is the file. try it out on your end and see if you get the error. fyi you dont have to uninstall other versions of s3d. you can have multiple versions on you machine that will all run.
Thanks jim, never would have found those. i'll try it again after I get the new computer up and running. (And at the risk of causing insta more heartburn, I have to ask one more question? What is netfabb? :lol: )
Last question insta, I promise!
Re: simplify3d v3.0
Post by jimc » Wed Jul 01, 2015 4:57 am
if you own a 3d printer then you should have netfabb installed on your computer. it really is a must. there is a free version. google it. download it. its a model repair software....more or less. there is also the cloud version which works awesome as well. actually this is the first thing i ever got an error with. i have also never in my life seen rhino export an imperfect stl. very weird.
https://modelrepair.azurewebsites.net/index.php
oh and if insta gives you a hard time...say "suck it insta" :lol:
Re: simplify3d v3.0
Post by Jules » Wed Jul 01, 2015 5:03 am
jimc wrote:if you own a 3d printer then you should have netfabb installed on your computer. it really is a must. there is a free version. google it. download it. its a model repair software....more or less. there is also the cloud version which works awesome as well. actually this is the first thing i ever got an error with. i have also never in my life seen rhino export an imperfect stl. very weird.
No way! :lol: (never PO the guy with the authori-taaay)
Thanks for the link, I'll be installing that little gem immediately!
Re: simplify3d v3.0
Post by insta » Wed Jul 01, 2015 3:23 pm
haha "authority"
I actually bought Netfabb. I use it a LOT more than I thought I would. I have it set to my default handler for STL files ... makes the "download, repair, export" workflow really fast.
Slipshine
Re: simplify3d v3.0
Post by Slipshine » Wed Jul 01, 2015 4:28 pm
Not to be nosy but what did it cost to buy?
