Call for sample prints
ketil
Re: Call for sample prints
Post by ketil » Thu Aug 14, 2014 12:25 pm
There are some really nice gliders available on thingiverse by the user "exosequitur". I haven't tried this one, but earlier versions of the Stratos glider were very cool!
http://www.thingiverse.com/thing:158421
mathisyourfriend
Post by mathisyourfriend » Tue Sep 09, 2014 12:38 am
I like the "torture test". Not an interesting thing but it's good for testing and adjusting your printer.
http://www.thingiverse.com/thing:33902
pyronaught
Post by pyronaught » Sun Dec 21, 2014 5:57 am
Some calibration models would be useful to have. Thin wall boxes, nesting boxes etc. There's some collections on thingiverse that have a half dozen or so calibration objects.
rsilvers
Post by rsilvers » Wed Apr 08, 2015 5:57 pm
I like the keychain thing.
CCVirginia
Post by CCVirginia » Mon Jun 01, 2015 10:12 pm
I would request some calibration models. Someplace there was a description of hand editing Gcode to print at multiple temperatures to help pick the right one. This and similar calibrations would be great.
04kmorri
Post by 04kmorri » Thu Jun 25, 2015 2:52 am
I think a 3dbenchy would work, it stress's a LOT of things that could be wrong with a print, such as over extrusion ( part is too tall or wide), x/y oscillation causing the #3dbenchy tag on the back of the boat to not show, and the holes in the front to have ghosting, if there are strings going for one side of a sizable opening to another there's a retraction/oozing issue, plus the dimensions are already specified if some one does a 1:1 model of it.
Farr0wn3d
Post by Farr0wn3d » Sat Jul 11, 2015 3:10 am
I designed a couple simple hexagonal coasters that would be easy prints and look kinda neat
http://www.thingiverse.com/thing:821948
This is the shorter one, takes half the time to print compared to the full height one
http://www.thingiverse.com/thing:821829
Vandal968
Post by Vandal968 » Sat Aug 08, 2015 11:52 pm
Everywhere I go that has 3D printers (hackerspaces, etc.) there are piles of worthless parts. Bigfoot heads, plastic octopi (the animal, not the 3D print server). I would have preferred if my MakerGear came with a couple of files for genuinely useful stuff instead of the bracelet and bigfoot head that I printed to test the machine. A few items that I've found indispensable:
Replacement fan mount to replace the lousy oem one which is prone to tipping and dragging the 50mm fan across your print. This one works awesome:
http://www.thingiverse.com/thing:348480
Super-useful tool rack to hold all those nice free tools that came with my printer:
http://www.thingiverse.com/thing:198825
Filament Spool clips. MakerGear filiment is awesome and the spools have the best built-in filament clip, but when using other brands like Hatchbox which has a horrible filament retention system, snap-on clips are handy.
(No link because I can't find the link to the one I liked best, ATM)
Raspberry Pi case for adding Octoprint or Astroprint to your MakerGear:
http://www.thingiverse.com/thing:922740
I think that the fan mount and tool holder should be the first two things printed by every MakerGear owner.
cheers,
c
Dale Reed
Post by Dale Reed » Tue Aug 11, 2015 2:16 am
Vandal968,
Glad you like the fan bracket. The files are there for anyone who wants to open it up and modify it in OpenSCAD -- perhaps reducing the depth of the shelf if you don't plan on putting LEDs underneath. (But having LEDs on it is just so useful for examining that critical first layer as it goes down.) As far as "legalities" are concerned, MG has my permission for unrestricted use of that thing, regardless of what the "Creative Commons License" says.
And I agree on the tool holder. I have the earlier one (from which the one you suggest was remixed), without the Z-wrench protrusion, and I agree it is absolutely essential to print early on. I also printed the 4-slot SD card holder ( http://www.thingiverse.com/thing:44339 ) and find it useful (although I wish it had a more permanent means and location of attachment to the printer).
But please keep the bigfoot head! They make great little gifts for nieces and nephews.
3d-cafe
Post by 3d-cafe » Sat Dec 05, 2015 12:29 am
I 'designed' the symbol ISO_7010_E002
It's the sign for emergency exit :D
It's very easy to print
ISOnotausgang.stl
(3.81 MiB) Downloaded 286 times
