While heating for a print (a print I've sent many times) My m2 started displaying Err; MAXTEMP on the VIKI.
The LCD and simplify both show a temp reading of 0 for the extruder and bed.
I've powered down, reset, disconnected and reconnected USB- and I always get the same error immediately upon powerup.
When the USB is connected I get twin flashing yellow lights right behind the USB connector.
Simplify 3D will connect, but no movement or temp commands work.
Any ideas? Reflash the board?
Err: MAXTEMP- Bed and Extruder bed temp 0
thecadman99
Re: Err: MAXTEMP- Bed and Extruder bed temp 0
the viki throws an element in there that i dont know anything about. the firmware is easy enough to flash. give it a go and see what happens. maybe some else with more useful info will chime in.
thecadman99
Ok, figured it out. Bad extruder thermistor- simple.
The bed reading 0 was throwing me- I was worried it was the board.
Swapped out the therm with one from another machine and its fine.... just need to get a new one.
Thanks for the reply Jim
