Question- is it more helpful to quality of print and life of machine if it were on a Rock solid surface and or mounted to one?
Or, would it be better for it to be on some heavy duty springs that give a little?
I know that for some large equipment it will be mounted on springs or else it will have parts that break.
~Michael
Mounting M2?
- pyronaught
Re: Mounting M2?
I was kind of wondering this too. The rubber feet on the machine allow it to shake a lot more during fast movements like fills than if it were bolted to a solid surface. The question then is that bad or good?
Re: Mounting M2?
I've also been itching to try solid mounting mine figuring just like a mill it would be more precise that way. My printer actually moves around on my table after time if I do infill on thinner walls. The only thing that concerns me would this lead to the extruder mounts cracking more? I've already had to print a new beefed up one after the first 4 months.
Soon as I'm done with my current project I might just have to give it a try and see what happens.
Re: Mounting M2?
I have mine ratchet strap to its table mostly to prevent it from walking off the table.
cliffwarner
Re: Mounting M2?
My M2 would do that as well when I first got it. I reduced the acelerations on my machine to improve the print quality and it no longer walks around. Print quality was improved as well. I implemented the change through the startup script in S3D by adding the line: M201 X900 Y900 Z200 E10000 to the starting G-Code.
- pyronaught
Re: Mounting M2?
Seems like the speed settings in the Other tab would override that macro being in the starting code block. I guess not if it is working for you though.cliffwarner wrote:My M2 would do that as well when I first got it. I reduced the acelerations on my machine to improve the print quality and it no longer walks around. Print quality was improved as well. I implemented the change through the startup script in S3D by adding the line: M201 X900 Y900 Z200 E10000 to the starting G-Code.
I was looking at the Ending code and saw the M84 command. In another thread someone was mentioning the issue of the platform dropping hard to the bottom after a print and one solution to that could be to just remove the M84 command or lower the platform with a G1 Z command prior to the M84 command so that it doesn't have far to drop.
Re: Mounting M2?
Acceleration is not the same thing as print/travel speed. The extruder can't go from zero to the target speed instantaneously. Acceleration controls how fast it attempts to ramp up. The S3D advanced tab sets those target speeds, the M201 controls the steepness of the ramp.
If you just remove the M84, the built in timeout will drop the table after a few minutes.
- pyronaught
Re: Mounting M2?
Thanks for the clarification, I didn't read the original post carefully enough. I'm surprised there is not also an acceleration setting in S3D the way there is in other CNC controllers.jsc wrote:Acceleration is not the same thing as print/travel speed. The extruder can't go from zero to the target speed instantaneously. Acceleration controls how fast it attempts to ramp up. The S3D advanced tab sets those target speeds, the M201 controls the steepness of the ramp.
Here's a useful link I found that defines all the macros specific to the Rambo board: http://reprap.org/wiki/G-code
