Is it normal that you must remove the usb cable after starting a print from SD card in order to get it to not pause?
When I try pressing Disconnect or closing S3D the print pauses and I cannot figure out how to restart it. It only seems to continue printing if I pull the usb cable which seems odd to me.
Printing from SD card...
Re: Printing from SD card...
yes if you want to print untethered then you usually start the print then pull the usb cable. that has atleast been the way i think most or all of us do it.
Ok. Thanks.
I thought you would want to click disconnect or close S3D before pulling the usb cable.
In the older firmware, doing a commanded USB disconnect (or something that causes one, like PC going to sleep, shutting down, etc.) caused the Rambo to basically execute the equivalent of a power-up reset. No idea what current firmware does, but I'm not one to risk a print, and I long ago got in the habit of just pulling the cable.
