For The Birds
Slipshine
For The Birds
Post by Slipshine » Wed Apr 22, 2015 6:15 pm
Printed with Makergear M2
Sliced Simplify 3d Creator 1.1.4
Layer height .15 mm
Print time 29 hours in 2 batches
1st batch 20 hours for main house body.
About 1.2 lbs of filament.
http://www.thingiverse.com/thing:117080
Bird Hous.jpg (76.46 KiB) Viewed 10224 times
Bratag
Re: For The Birds
Post by Bratag » Wed Apr 22, 2015 7:26 pm
Great print!!!
Hope the birds appreciate the low layer height finish :)
Re: For The Birds
Post by jsc » Wed Apr 22, 2015 7:59 pm
Bratag wrote:Hope the birds appreciate the low layer height finish :)
"Look at this, Bob! You can barely see the layers!"
Re: For The Birds
Post by Jules » Wed Apr 22, 2015 8:48 pm
I like the fact that the finishing work is greatly reduced. Does that add a lot of time to the print? :)
Bratag
Re: For The Birds
Post by Bratag » Wed Apr 22, 2015 10:00 pm
Jules wrote:I like the fact that the finishing work is greatly reduced. Does that add a lot of time to the print? :)
Lets take your .15mm print - lets say we have an object thats 15cm high that's going to require about 1000 lines to print give or take a few
Now lets bump the layer height up to .25mm - now we only need 600 lines to print the same object.
Granted you lose a little quality on the finish but if you are planning on painting (or my suggestion for stuff that goes outside XTC-3D) then chances are you are going to smooth out the lines in post anyway.
Don't get me wrong I do print at low res but usually I am like Maverick in Top Gun - I feel the need ... the need for speed. Especially on large prints like this one.
Re: For The Birds
Post by Jules » Wed Apr 22, 2015 11:36 pm
Yeeps! That's like 67% longer! :shock:
(Really does make you appreciate a fine finish.....'specially on a larger print.)
