Ohms to high on thermistor?
recently I've been having problems with my extruder so I checked the resistance on the thermistor and it measured 112.7k ohms. is this good or is their a short?
Re: Ohms to high on thermistor?
That's not an unheard of value (they are 100k thermistors). I'd contact MakerGear support directly at this point.DeadLaine wrote:recently I've been having problems with my extruder so I checked the resistance on the thermistor and it measured 112.7k ohms. is this good or is their a short?
okay, should I also measure the ohms of the cartridge heater as well?
Whatever support asks you to doDeadLaine wrote:okay, should I also measure the ohms of the cartridge heater as well?
thanks for the help, they are sending me a replacement thermistor. hopefully this does the trick!
