Slicing help??
jereywolf
Slicing help??
Post by jereywolf » Sat May 02, 2015 6:28 pm
So here is the model that I'm trying to print. I made this model in Solidworks.
cersei necklace first render.JPG (259.55 KiB) Viewed 5943 times
Here is the model in S3D.
stl on table.PNG (313.14 KiB) Viewed 5943 times
This is what I get after slicing it.
And here is the pint that I had to stop after I got a build-up on the nozzle.
pendant slicing print.jpg (80.29 KiB) Viewed 5943 times
I tried to use netfabb to repair the model (just to see it that would help) and kept getting an out of memory error.
I don't think there is an issue with my model. I made it all with solid geometry.
If you have any suggestions or would like to try it yourself I can send you the .stl. (it's a large file and wouldn't upload here easily.)
Re: Slicing help??
Post by jsc » Sat May 02, 2015 6:47 pm
Are you sure those bumps aren't hollow on the inside?
jereywolf
Re: Slicing help??
Post by jereywolf » Sat May 02, 2015 7:09 pm
After reading your response, I thought about the way that I built the file. It was exported from a Solidworks assembly and every single feature was a separate body. I went back to the model and combined everything into a single body and the preview looks spot on now. Thank you jsc! :D
