I have a pre-assembled 12V/19V M2 from June of 2013. It has be working great ever since I got it and has been incredibly reliable.
Suddenly upon startup, the two 40mm fans (extruder and electronics case) no longer fire up. I can't get the 50mm bed fan to respond to M108 S255 and nothing happens with M106 S255 for the 40mm fans. The jog commands and bed heater work properly, but the extruder heater does not.
Here's what I've done to isolate the problem so far:
- Confirmed that each fan works when connected to an external 12V source
Checked all the wiring connectors for tightness and/or damage
Verified that the Dell brick 12V power supply is putting out 12V
Tested continuity from RAMBo connections up to the top to check for broken wires. Also wiggled wires to test for intermittent issues.
Checked the 15A automotive fuse
Re-uploaded the firmware
The only thing that has changed recently is that I had a second 40mm 12v fan connected in parallel to the extruder fan for about a week. Could this have caused an issue and fried my RAMBo? I know adding it in series would alter voltage, but thought parallel was harmless.
Any ideas are appreciated.
