I want to print a new filament drive, but Slic3r is letting me down with support generation. Could someone be kind enough to run the Attached filament drive through S3D for the following specs:
Stock M2 V3B with fan duct, binder clips on HBP
esun PETG Black
1.78mm
1.05 multi
250C Hot End Temp (first layer and on)
100C Bed temp
0.25 Layer Height (first layer and on)
0.4 Extrusion Width (all)
90% linear infil (unless if you recommend otherwise.)
Conservative speeds (75 Infil 50 for others and below for fine print.)
-0.05 Z Offset
1mm retraction
60mm/s retract speed
Let me know if you need anymore info.
UN-solved: Need a S3D GCODE
- Matt_Sharkey
GCode Delivered, Thanks Jules!
- M2 Filament Drive r2.zip
- (349.63 KiB) Downloaded 652 times
Last edited by Matt_Sharkey on Tue Aug 04, 2015 12:58 am, edited 6 times in total.
- Matt_Sharkey
Re: Need a S3D GCODE
V3BJules wrote:Do you have V3B or V4?
Sorry, I know this is taking a while, but the new version of S3D has some issues with integrating its support through walls instead of next to them.
I'm gonna regenerate manual support with the older version. Take a coffee break, i'll finish tweaking this.........
- Matt_Sharkey
No worries, lets put this on pause for a moment, I just realized that i need to quickly recalibrate, I'll be back with new numbers.
Okay, i need to feed the kitties....(and maybe me too!) Just post your new settings when they're ready, I've got the support created.
Open a support ticket. MakerGear has this GCode for a v3b machine.
- Matt_Sharkey
do I send them the same specs, or is it a generic gcode?insta wrote:Open a support ticket. MakerGear has this GCode for a v3b machine.
I'm having a nighmare trying to level this bed...
- Matt_Sharkey
That moment you realize that you have "sprial vase" checked off.....Matt_Sharkey wrote:I'm having a nighmare trying to level this bed...
