Hello,
I am a new (and proud) owner of an M2 3D Printer (My first 3D Printer) and after my 3rd print I ran across a weird problem. I started my 4th print, then stopped (to re-size the print) by turning off the power supply, since I didn't feel like waiting for it to pause and then having to press restart and go over the whole process to stop and start a print (Also because I sorta couldn't find how to stop a print in Pronterface, but now I know how to
). Now whenever I go to print an object, the first few layers won't print, then it'll start to extrude filament. Two things that makes me think this is not a clogged nozzle is because when I do manual extrusion via Pronterface, it will work. If I try to push the filament through while it is printing the blank layers, it seems to make it start to extrude, even after I stop pushing it through. The nozzle/bed has reached the set temperature, by the way, and the stepper motor for the filament is moving. Another weird thing is that whenever I start the print, it'll home XYZ, then go off to the right side of the build plate and lower the build plate, almost like it is heating up the nozzle/bed. When it is on the right side of the build plate, it will also extrude some filament (Also, it is practically extruding filament right onto the fan in the controller box thing). After it is done extruding some filament, it will start the print. Like I said before, the first few layers will be blank, then it will start to extrude filament. Whenever I print the stock bigfoot head in the SD, it will lower the build plate all the way down before it starts to extrude. Whenever I print the stock bracelet in the SD, it will just not print the first few layers, then start to extrude filament. I don't blame you if you just got confused
.I will upload a video of what is going on, if requested. Thanks for the awesome printer Makergear, and I hope I will be up and printing soon! (Also, how do I control fans in Slic3r?
Thanks,
Cyber_Gram
