BLTouch Auto Leveling Sensor
stottsjr
Re: BLTouch Auto Leveling Sensor
Post by stottsjr » Sat Feb 03, 2018 3:38 am
Sounds like it's doing what it's supposed to be doing. Can you capture a video and post it somewhere?
sonra
Post by sonra » Sat Feb 03, 2018 12:41 pm
Hi
I found the problem .The sensor tip when in push position ( down ) was a little above the extruder , so the table when try to go to home position crushed into the extruder and not the sensor . Now i put spacer so the sensor tip is below the extruder and G28 and G29 do the job
sonra
Z PROBE_OFFSET_FROM EXTRUDER
Post by sonra » Thu Feb 08, 2018 8:16 pm
Hi ,
I have the M2 with v4 extruder ,use Samplify as control software . I installed the BLTouch sensor and one of my of setting I am not sure about is the
Z PROBE_OFFSET_FROM EXTRUDER in the configuration.h ,what is the best way to define it and how it change or not the setting of Globel G code Offset in the Simplify process setting .
regards Doron
stottsjr
Post by stottsjr » Fri Feb 09, 2018 3:56 am
It's trial and error. All printers will be different even ones of the same model.
M851 will be your friend in figuring it out and you'll use the "Communication" tab in the "Machine Control Panel" in Simplify3D.
You'll basically set an offset with M851 like:
M851 Z-1.5 // These numbers are in MM and you can go 2 significant digits i.e -1.55
If you're running into the bed then you're too low and you'll have to add positive numbers, if you to high then you add negative numbers.
I find that you should do a home all or a G28 after each setting of the M851 to verify the new setting and repeat until you get the correct one for your printer. Once you figure out your number then you change it in the firmware and upload it.
Post by ednisley » Fri Feb 09, 2018 1:31 pm
stottsjr wrote:It's trial and error [...] M851 will be your friend
Having just replaced the hot end thermistor, I tried setting the new nozzle offset with M851 and found it had no effect, at least with Marlin 1.1-RC5, a two-year-old version supposedly supporting M851. Perhaps M851 only participates in complex Z probing, but the G-Code doc isn't forthcoming.
M206 worked, after some protracted headscratching, with M500 to store the final offset value:
Bottom line: trial-and-error also applies to discovering which G-Code works with the firmware in your printer!
sonra
Post by sonra » Fri Feb 09, 2018 2:12 pm
Hi
May be i don't understand what I suppose to happen but i try to describe what i see
1) I sent a M280 P0 S10 command to drop the tip down . the tip is about 2 mm below the extruder
2) I send M851 with Z negative number
3) I recive a message "echo:Z Offset ok"
2) I send a G28 command
The bed hit the tip and the extruder is about the 1.5 mm above the bed .I tried to change the number to -3 or -0.1 but got the some result
What am I doing wrong ??
Doron
stottsjr
Post by stottsjr » Fri Feb 09, 2018 11:43 pm
Yeah, I'm using Marlin 1.1.8 since it has more features and better options for bed leveling.
Your switch looks like a limit switch (So it's probably not sending the correct signals.) and not a BLTouch and this might be the cause of your issues.
You can see a true BLTouch in this thread.
viewtopic.php?f=10&t=6418
sonra
Post by sonra » Sat Feb 10, 2018 12:11 am
I am using the BLTOUCH . Do i have to adjust the Z offset number only when I try to print and if the print is not OK or there is other way to do it ?
I mean can I enter as default -1.55 and adjust it according print results or is any way to do it ?
Post by ednisley » Sat Feb 10, 2018 3:04 pm
stottsjr wrote:Your switch looks like a limit switch
Aye, because the BLTouch solves a problem I don't have.
Point was: maybe Doron's problem comes from a Marlin firmware version mismatch, where the proper commands don't do quite what's expected.
sprior
Post by sprior » Wed Feb 14, 2018 9:38 pm
Ed, since you mentioned you aren't using a BLTouch (which I installed this last weekend in my M2) are you doing Z sensing but not bed level compensation with that switch? It looks like maybe you sense Z with the nozzle off the edge of the bed, but the switch over it?
