M2 Rev. E Dual Extruder Firmware
Post by Jules » Sun Apr 17, 2016 5:01 am
If you are having trouble with the new Rev.E machines recognizing the T1 extruder after installing the firmware recommended in the installation instructions, use the firmware below:
(Remember to use the 1.5.5 version of Arduino to flash the firmware.)
M2E-Production-SnNRd-V101 - Dual.zip
(1.06 MiB) Downloaded 757 times
Farr0wn3d
Re: M2 Rev. E Dual Extruder Firmware
Post by Farr0wn3d » Wed May 18, 2016 8:09 pm
I hadnt tried that, I'm using the ones on the MG Wiki. I tried compiling the one you posted but I'm getting an error. The other issue I have is that I can get a version that will run the dual, and use the inverted z endstop but not the LCD. Other versions will do the LCD and inverted Z but not the dual. lol
Farr0wn3d
Post by Farr0wn3d » Wed May 18, 2016 8:17 pm
OKAY, so uninstalling the new arduino version and installing the v1.5.5 and loading the firmware you provided works. Now my only question is how to you set the z height if theres no bolt to adjust for hitting the endstop??
Post by Jules » Wed May 18, 2016 8:28 pm
Farr0wn3d wrote:OKAY, so uninstalling the new arduino version and installing the v1.5.5 and loading the firmware you provided works. Now my only question is how to you set the z height if theres no bolt to adjust for hitting the endstop??
You don't... the little app sets a "Starting Height" now, and from that point on - it's automatic.
viewtopic.php?f=3&t=3542
Farr0wn3d
Post by Farr0wn3d » Wed May 18, 2016 8:44 pm
Does that app adjust a value in the firmware?
Post by Jules » Wed May 18, 2016 9:04 pm
Farr0wn3d wrote:Does that app adjust a value in the firmware?
Yep! It sets it.
Farr0wn3d
Post by Farr0wn3d » Wed May 18, 2016 9:12 pm
Whats the value called so I can edit it myself in the firmware?
Post by Jules » Wed May 18, 2016 9:54 pm
ROFL! No idea! I use the App. :lol:
Here's the thread where the guys who know what they are doing worked it out:
viewtopic.php?f=10&t=3072
zemlin
Post by zemlin » Thu May 19, 2016 2:55 am
Farr0wn3d wrote:Whats the value called so I can edit it myself in the firmware?
This might be the info you're looking for
viewtopic.php?f=3&t=3631
