Cant set the Tension with Filament Drive Screws for ABS
wisdomknight
Post by wisdomknight » Sun May 22, 2016 7:16 pm
I orginally had no problem changing from the black PLA to my gray hatchbox ABS.
Then I swapped out to try out hatchox wood and hatchbox gray PLAY, no probs at all
Now I wanted to go back to the ABS after a week and I cannot for the life of me get it to take it in again.
I have my hotend set to 250 and I went back to PLA woth no problems.
The only thing I noticed is as it was trying to take in the ABS I seen little tiny ABS chips coming off it as it tried.
I tried to adjust the tension screw for a half hour straight with no luck no matter how much I adjusted it less or more.
Any help would be appreciated as I really like ABS much more then PLA
Re: Cant set the Tension with Filament Drive Screws for ABS
Post by Jules » Sun May 22, 2016 7:20 pm
This might help:
viewtopic.php?f=3&t=2694
wisdomknight
Post by wisdomknight » Sun May 22, 2016 7:27 pm
I will keep trying. I def heard that thunking sound as well as I tighten more.
Thank you
Post by Jules » Sun May 22, 2016 8:24 pm
Yeah, definitely too much tension. ;)
