Started up my machine for the day; got the heat started, and heard a buzz sound. Looked up real fast and saw sparks coming from heated end. Before I could hit the my fans stopped working.
Turned the machine off as fast as I could; unplugged the hotend. I am not sure if the sparks were from the heater or thermostat, but definitely came from that area.
Now machine will not turn on, fans don't start, wont connect, etc
I checked the fuse in the pc board, it does not seem shorted out!
I have submitted a support request but was wondering if anyone else had any ideas?
Did my board just short out?
Re: Did my board just short out?
There are three fuses on the board did you check them all? .
If it started as a hotend issue and the fans stopped working F3 is where I'd look first.
jcspball13
I did not know that! Wew; ok if it is a smaller fuse where do I buy new ones?
jcspball13
But also why did the hot end do that? It is actually pretty new
My original hot end just had the thermostat piece come out completely; how do I reinstall that?
MakerGear Support, or Ultimachine.jcspball13 wrote:I did not know that! Wew; ok if it is a smaller fuse where do I buy new ones?
jcspball13
After some awesome customer support from makergear, everything is back up and running!
Thanks to everyone who helped!
