Cura 2.3.0 MakerGear M2 file
imaric
Re: Cura 2.3.0 MakerGear M2 file
Post by imaric » Mon Feb 04, 2019 6:40 am
Before I looked at this post, I tried to setup latest Cura myself for M2 printer (older version, Rev D I believe). Everything seemed fine, but when I started printing from cura, it lifted the bed too high, the nozzle ripped the tape and started printing on glass. Not sure if it was trying to lift bed even more, but each following layer was printed on the glass- pushing the previous layer aside. Is it possible that I need to reverse Z axis direction?
With other SW/options everything works like a charm:
Used Repetier Host that used this latest Cura as slicer (I have set only build plate size, nozzle dia and temperatures) and printed directly from repetier Host-no issues. Also, I was able to make successful prints using Slic3r and M2 quick start, via Memory card. Also, used older Cura on another PC, also via mem card and M2 Quick Start.
Thanks, happy printing!
Gwhite
Post by Gwhite » Tue Feb 05, 2019 2:54 am
At some point, they reversed where the Z axis "home" position is located. On the Rev. E, the Z limit switch is with the platform all the way down. I'm not sure when they changed, but the older versions of the M2 had the Z limit switch at the top. It sounds like that's where your problem originates.
dfwspeed
Post by dfwspeed » Wed Apr 03, 2019 5:18 pm
Does anybody have a config file for cura 3.6?
Greentoast
Post by Greentoast » Mon Aug 05, 2019 3:27 pm
Hi, I was also wondering if anyone had a Cura profile for the more recent software. I have always been curious about the software but have not found anything that works yet. Thanks.
Greentoast
Post by Greentoast » Wed Aug 07, 2019 4:09 pm
I have recently added your Cura profile but am unable to add a second extruder as I have a dual extruder setup. Any thought on how I might be able to add that? Thanks in Advance.
Gwhite
Post by Gwhite » Thu Aug 08, 2019 1:17 am
Do you have Cura working well for a single extruder? What version of M2 are you using, and which version of Cura? I've got a single extruder M2E that I'd love to get working with the latest version of Cura, which appears to be up to 4.2.1.
