Highly customizable Simplify3D profiles
Post by insta » Sun May 21, 2017 2:29 am
These are new, and untuned. What their value is, is that I have actually learned what you can do with the S3D profiles finally.
For instance, my "TPU" filament can change the print speed vs. "PETG" vs. "PLA". The temps change, the rafts change, etc. (yes, I occasionally still use rafts, there's reasons, shush)
Open the files up in Notepad++ or SublimeText 3 (or some other competent, free, XML editor). Look at this example for TPU:
Code: Select all
    <autoConfigureMaterial name="TPU">
        <filamentPricePerKg>15</filamentPricePerKg>
        <filamentDensity>1.20</filamentDensity>
        <useRaft>0</useRaft>
        <defaultSpeed>1200</defaultSpeed>
		<extruder name="Primary Extruder">
			<extrusionMultiplier>1.33</extrusionMultiplier>
			<retractionSpeed>1500</retractionSpeed>
			<retractionDistance>.6</retractionDistance>
		</extruder>
        <temperatureController name="Primary Extruder">
            <setpoint layer="1" temperature="200"/>
        </temperatureController>
        <temperatureController name="Heated Build Platform">
            <setpoint layer="1" temperature="40"/>
        <fanSpeed>
            <setpoint layer="1" speed="0"/>
        </fanSpeed>
    </autoConfigureMaterial>
See the "<extruder name" tag? You can use that to override specific behaviors for any autoconfigured plastic. What behaviors are available for an extruder? At a minimum, these seem to be:
Code: Select all
        <toolheadNumber>0</toolheadNumber>
        <diameter>0.75</diameter>
        <autoWidth>0</autoWidth>
        <width>0.9</width>
        <useRetract>1</useRetract>
        <retractionDistance>1</retractionDistance>
        <extraRestartDistance>-0.3</extraRestartDistance>
        <retractionZLift>0.5</retractionZLift>
        <retractionSpeed>4500</retractionSpeed>
        <useCoasting>1</useCoasting>
        <coastingDistance>0.3</coastingDistance>
        <useWipe>0</useWipe>
        <wipeDistance>5</wipeDistance>
    </extruder>
So, any property that's available in those tags can be overridden on a per-plastic basis. Same with any top-level XML tag. This includes skirt behavior, infill behavior, top & bottom layers, etc. You can also nest top & bottom layers, support behavior, infills, etc. inside of the quality elements, like I do here:
Code: Select all
    <autoConfigureQuality name="0.20mm layer">
        <layerHeight>0.2</layerHeight>
        <topSolidLayers>4</topSolidLayers>   *********
        <bottomSolidLayers>4</bottomSolidLayers>
        <skirtLayers>2</skirtLayers>
        <infillPercentage>30</infillPercentage>
        <supportInfillPercentage>40</supportInfillPercentage>
        <firstLayerHeightPercentage>100</firstLayerHeightPercentage>
        <firstLayerWidthPercentage>105</firstLayerWidthPercentage>
        <firstLayerUnderspeed>0.3</firstLayerUnderspeed>
        <supportExtraInflation>0.2</supportExtraInflation>
        <denseSupportLayers>2</denseSupportLayers>
        <denseSupportInfillPercentage>70</denseSupportInfillPercentage>
        <supportHorizontalPartOffset>0.5</supportHorizontalPartOffset>
        <supportUpperSeparationLayers>2</supportUpperSeparationLayers>
        <supportLowerSeparationLayers>1</supportLowerSeparationLayers>
    </autoConfigureQuality>
    <autoConfigureQuality name="0.10mm layer">
        <layerHeight>0.1</layerHeight>
        <topSolidLayers>6</topSolidLayers>      ************
        <firstLayerHeightPercentage>150</firstLayerHeightPercentage>
        <firstLayerWidthPercentage>125</firstLayerWidthPercentage>
        <denseSupportLayers>3</denseSupportLayers>
To get this XML, export your settings as an FFF. Merge your tuned settings into my base-line profiles, consolidate them, and re-merge them back together. Any questions about specifics, please feel free to ask. Enjoy!
M2 - 75.fff
(16.62 KiB) Downloaded 1302 times
M2 - 60.fff
(17.57 KiB) Downloaded 1297 times
M2 - 50.fff
(17.56 KiB) Downloaded 1218 times
M2 - 35.fff
(17.56 KiB) Downloaded 1319 times
M2 - 25.fff
(17.56 KiB) Downloaded 1237 times
psd
Re: Highly customizable Simplify3D profiles
Post by psd » Sun Oct 01, 2017 3:11 pm
Think this may be over my technical comprehension. Is it possible to provide a full fff profile with all materials you have established till now?
- peter,
www.petersolomondesign.com
psd
- peter,
Post by insta » Sun Oct 01, 2017 5:30 pm
Yeah, they're attached to the original post :)
psd
Post by psd » Sun Oct 01, 2017 6:18 pm
Just saw them, sorry was looking from iPhone before and didn't see the attachments, what are the differences between versions?
- peter,
psd
Post by psd » Mon Oct 02, 2017 3:28 pm
insta wrote:Yeah, they're attached to the original post :)
whats the difference between:
M2 - 75.fff M2 - 60.fff M2 - 50.fff M2 - 35.fffn M2 - 25.fff
is this a speed setting?
thanks!
- peter,
Post by insta » Mon Oct 02, 2017 4:25 pm
nozzle diameter
psd
Post by psd » Sat Oct 07, 2017 12:51 pm
thanks Insta,
is it possible to modify your FFF files in S3D and save rather than in XTML?
I am lost when it comes to looking at lines of code and I don't want to make mistakes.
I am getting better with the settings in S3D and wouldn't mind just tweeking the FFF files when needed.
- peter,
Post by insta » Tue Oct 10, 2017 9:19 pm
They're in the system registry, once it gets imported. It's a huge pain to try and parse / synchronize them.
psd
Post by psd » Tue Oct 17, 2017 9:22 pm
I am using your FFF profiles and liking them. The only problem is the ending script is raising the Z axis after printing so it is knocking over my prints and breaking them.
Did I do something wrong with the scripts?
Can you copy and paste the best ending script please for me?
thanks!
- peter,
