Thumb screw for M2 Bed Leveling
makeal
Re: Thumb screw for M2 Bed Leveling
Post by makeal » Mon Nov 19, 2018 4:11 pm
psd wrote:
Sun Nov 18, 2018 3:55 pm
Cut with a metal hack saw ($2 small version from Home Depot or dollar tree works fine.) try not to skip over threads with saw. After cutting put a 45 degree chamfer on cut end by putting knob in vice and using a metal file on it or passing over a sander.
thank you
psd
Post by psd » Mon Nov 19, 2018 4:32 pm
you are welcome!
post your make on thingiverse if you make them!
- peter,
www.petersolomondesign.com
jferguson
Post by jferguson » Tue Nov 20, 2018 1:42 am
If it is an ANSI threaded screw (this one isn't) and number 10 or smaller, I can usually shear it off pretty cleanly with my stripper/ crimping tool. If it's Metric (this one is) I grab it in a vise and using a cut-off wheel in a hand grinder (Dremel tool) cut off the portion that makes it too long. I usually run a nut down the length of it which will clean up the thread when I remove it after the cut. I also like to clean up the end with a grinder. Given the size of this one, though, this can be a bit tricky.
BTW, the design of this improvement is really nice. :D
makeal
Post by makeal » Tue Nov 20, 2018 2:15 pm
Thank you for the tips. Came across this https://www.amazon.com/Antrader-M4x16mm ... 07K698LLX/ these are 16mm which should work without cutting
