My M3ID appears to be dead :-(
Explorer74
Post by Explorer74 » Sun Dec 17, 2017 4:11 pm
I had my M3ID lock up again in the middle of a print. I shut the system down and when I came back a couple of days later I could not connect to the printer. When I turn it on the power supply comes up and the PI lights up, but the printer does not power up. The only light in the electronics box is a dim green light at the USB connector. The fan does not come on and the printer does not make the little noise it usually makes when it powers up. I have checked the power connection and it is good ( or the PI wouldn't have power). At this point I am really frustrated. Anyone have any suggestions ?
Re: My M3ID appears to be dead :-(
Post by Tim » Mon Dec 18, 2017 4:36 am
The electronics board has three fuses, one large automotive one and two small surface-mount type parts in little sockets. I don't think that these have changed in the RAMBo revisions since the one I have. Remove each of these, starting with the automotive fuse, and check for continuity.
If a fuse has blown, then it's important to figure out why it blew, otherwise plugging in a new one is just going to cause it to blow again. Sounds like something shorted, in which case your best bet is to go straight to MakerGear for help. Don't worry---they'll get you up and running again.
jk42
Post by jk42 » Mon Dec 18, 2017 3:48 pm
I agree with Tim. If you haven't done so, please open up a ticket with us at support@makergear.com
It does sound like a blown fuse. We need to figure out if it is and why this is happening.
~Jason from MakerGear
Explorer74
Post by Explorer74 » Tue Dec 19, 2017 4:24 pm
I checked the fuses. They are all good. I talked with Michael at MakerGear support. We finally figured out that the USB cable I had connecting my printer to my laptop was interfering with the wifi commands. I unplugged the cable and everything worked :-) When I first got the M3ID I plugged in the USB cable because that is how I used the M2. I didn't realize the wifi talking to the build in PI with OctoPrint was fighting with the USB cable all this time.
Post by Tim » Wed Dec 20, 2017 4:13 pm
Huh. I would not have expected the combination of WiFi and USB to make the machine completely unresponsive. Thanks for posting a follow-up with the resolution; that will certainly help users in the future if they run into the same issue.
Explorer74
Post by Explorer74 » Thu Dec 21, 2017 7:23 pm
Apparently it doesn't usually affect the printer. I had been using it like that for several months. There was one previous occasion when the printer just stopped and locked up in the middle of a print. I guess it runs normally on wifi through the PI, but occasionally the USB sends something that makes the printer spasm. Weird. Glad I got it figured out :-)
