MIC 6 plate and PEI
sonra
MIC 6 plate and PEI
Post by sonra » Wed Mar 21, 2018 7:55 pm
Hi guys
I try to print PLA on the MIC6 plate covered with PEI plate . till now with not great success ( the start print layer does not stick well ) .
To what temp. ( in C degrees ) do you heat the plate ?
Regards Doron
Phil
Re: MIC 6 plate and PEI
Post by Phil » Wed Mar 21, 2018 9:02 pm
Plate temperature depends on the PLA you are using. I use 45C-60C for the PLAs I print. More importantly is to ensure your bed is CLEAN; I usually wipe it with acetone or glass cleaner. Secondly, ensure you are 'squishing' your first layer enough. You may try turning your Z-axis knob one click closer.
Post by sthone » Wed Mar 21, 2018 9:17 pm
If you bed height is correct and it's not sticking to PEI you can try scuffing the PEI surface slightly with steel wool to help with adhesion.
sonra
Post by sonra » Fri Mar 23, 2018 4:30 pm
Thanks for help .The bed was not very leveled
Doron
