Nozzle Has a Gap/Not Flush with Heater Block
walt
Post by walt » Wed Aug 22, 2018 7:58 pm
New to MakerGear and looking forward to using my new printer. I changed out the default .35mm nozzle with a .75 nozzle. However, I noticed that there's a gap between the new .75 nozzle and the heater block whereas the out of the box .35mm nozzle was flush with the heater block (see photo showing the gap Image). Is this normal? It seems like the heat transfer would be lower if there's a gap. I measured the inside threads, and the .75mm nozzles seem to be about .17mm shallower than the .35mm nozzles which would explain the difference. Note I have two .75mm nozzles and they both have this issue. Obviously I don't want to over tighten the nozzles and the gap is large enough that I don't believe I can close it anyway. Any help or guidance is appreciated.
Re: Nozzle Has a Gap/Not Flush with Heater Block
Post by airscapes » Wed Aug 22, 2018 8:55 pm
Make sure there isn't any plastic hanging out of the hot end. I did that with a normal nozzle once.. Don't have a .75 so no idea.
walt
Post by walt » Wed Aug 22, 2018 8:57 pm
Thanks - no plastic on the hotend. The old nozzle goes right back on and sits flush.
