side skirt
turtleman
side skirt
Post by turtleman » Wed Nov 28, 2018 1:07 pm
I want to put on a side-skirt to help hold down my part when printing. How do I do that? I have a M2
jprochnow
Re: side skirt
Post by jprochnow » Wed Nov 28, 2018 1:19 pm
You want a brim. That extends the bottom surface to help with adhesion.
Re: side skirt
Post by airscapes » Wed Nov 28, 2018 2:14 pm
If you are designing the part, you would do that in the cad software.
If you are using other peoples parts you would use a brim as was suggested. If you are using Simplified 3D you do the in the additional tab, under skirt, use 1 layer, 0 offset and multiple outline.. start with 5 and see how that works.
Hope that helps
