M3-ID LCD Controller
Pr02type
Post by Pr02type » Thu Nov 29, 2018 8:14 pm
Hello, my first post here.
Is the LCD interface available on the main website compatible with the newer M3-ID?
Or is it only available for the M2?
If it's not compatible, are there and other options for LCD and SD card modification?
makeal
Re: M3-ID LCD Controller
Post by makeal » Fri Nov 30, 2018 3:38 pm
Don't have M3 but it uses Rambo 1.3 board which has LCD support. Its probably not enabled in the firmware. Makergear officially doesn't support it but it might work. You will need to enable LCD support on the firmware and upload it to m3.
This is the line you need to uncomment:
I pulled this from M2 firmware
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Again I don't have an M3 so this was never tested.
Pr02type
Post by Pr02type » Tue Dec 04, 2018 7:20 pm
Thanks for the reply. I will give that a shot.
cysayles
Post by cysayles » Sat May 04, 2019 11:49 pm
Did you ever try and see if it would work?
