Octoprint Custom Control Development
paynterf
Post by paynterf » Mon Jan 04, 2021 5:03 pm
<r>Hi,<br/>
<br/>
I've just started working on some custom controls for the Octoprint web interface to my M3-ID printer. I've added the Custom Controls Editor plugin to my Octoprint setup, and have used it to create some very basic controls, but it isn't very well documented, and is no longer being supported. <br/>
<br/>
I also managed to create some custom controls by directly editing the config.yaml file on the Octoprint server, but this too has it's problems. One big problem is the apparent difference between the YAML syntax recognized by the M3-ID variant of Octoprint and the syntax described in the Octoprint.org documents pertaining to YAML. <br/>
<br/>
the order of the lines comprising a command section appears to be reversed from the docs: For instance, this is an example command section from the Octoprint.org docs:<br/>
<CODE><s>
Code: Select all
</s> - name: Example for multiple commands
    children:
    - name: Move X (static)
      confirm: You are about to move the X axis right by 10mm with 3000mm/s.
      commands:
      - G91
      - G1 X10 F3000
      - G90
    - name: Move X (parametric)
      commands:
      - G91
      - G1 X%(distance)s F%(speed)s
      - G90
      input:
      - default: 10
        parameter: distance
      - default: 3000
        parameter: speed
<e>
</e></CODE>And this is the arrangement that actually works on the M3-ID:<br/>
<CODE><s>
Code: Select all
</s>- children:
  - commands:
    - G91
    - G1 X10 F3000
    - G90
  - commands:
    - G91
    - G90
    input:
    - default: 10
      parameter: distance
    - default: 3000
      parameter: speed
  layout: horizontal
  name: Example of multiple commands
<e>
</e></CODE>
As you can see, they are almost inverses of each other, rendering most of the Octoprint.org examples nearly useless for learning.<br/>
<br/>
Does anyone know how/why there are such large differences in YAML syntax, and if there any docs or references that describe the M3-ID variant of Octoprint YAML syntax?<br/>
<br/>
TIA,<br/>
<br/>
Frank</r>
