I have an older M2 w/dual Extruders… circa 2010ish.
I woke after an overnight print to find that the print failed and machine stopped with what seemed to be strange noises coming from the M2. After investigation the power was at 14v, and the power supply was acting strange when cycled… abnormal clicking noises from inside the PS. I swapped out with a new PS and problems, albeit different problems persist.
After the PS swap, now when I start a print the bed begins to heat then it immediately shuts down. I can cycle the PS, and start over but the same things happening. I assume the Heated bed is shorted and tripping the PS.
Before I go any further, can anyone shed light on my issue or how to check the heated bed?
Thank you
Power issues
Re: Power issues
Ok I decided to try a couple scenarios. I tried printing w/out bed heat and ran into the same issue where the PS shuts down. This leads me to believe my RAMBo is fried. When power is switched to either the Ext or Heated Bed the PS shuts down. I would assume there is a short somewhere... any ideas on where on the board to test?
