Does M2 Marlin Firmware Support "Stealth Mode"?
Gwhite
Post by Gwhite » Thu Dec 31, 2020 7:57 pm
I'm setting up a configuration in PrusaSlicer for my M2E. One checkbox is for "Supports Stealth Mode". I'd never heard of this, but I figured I'd ask if the MakerGear firmware supports it. It apparently slows/smooths things down so it's not as noisy.
Re: Does M2 Marlin Firmware Support "Stealth Mode"?
Post by airscapes » Thu Dec 31, 2020 8:11 pm
Not sure about that G, but I have attached a PS project file of a PETG printed model. Made this on PS 2.3 rc2 but I think you can import it and it should all just work. Can you try it for me? The think I don't know is if includes all the data like a factory file. I have printed this model with this config 4 times and all looked better than the 4 I did with S3D as I think I told you the other day in a different thread.
Doug
Can not attached here is the 3mf file
https://misc.airscapesart.com/prusaslic ... leg_V1.3mf
This is the ini file, right click and save or it will just show up as text
https://misc.airscapesart.com/prusaslic ... bundle.ini
Bioluminous
Post by Bioluminous » Thu Dec 31, 2020 8:20 pm
On my Prusa MK3, you select stealth mode on the printer screen. On my M2 screen, I don't see any setting that would be equivalent so I don't think it's part of the firmware. Same with on my M3.
