How to stop the heating bed at s3d
Posted: Thu Jul 10, 2014 1:05 am
by jccdesign
Hi i want to use blue tape , but dont know how to stop the bed from heating
Re: How to stop the heating bed at s3d
Posted: Thu Jul 10, 2014 1:07 am
When you run a print, the temperatures are baked into the gcode file when you prepare to print. Edit process settings, temperature tab, then click on Heated Bed. Remove all the setpoints.
Posted: Thu Jul 10, 2014 1:12 am
by jccdesign
i tried and it says " each temperature is required to have at least one poit definition"
Posted: Thu Jul 10, 2014 1:14 am
by jccdesign
ok so i have to create a new layer set point instead of saying 1 60 , create one that says 1 0 ?
Posted: Thu Jul 10, 2014 1:17 am
Hm, never really noticed that before. Maybe it's new. Or maybe I just never tried it.
You can remove the Heated Bed controller entirely, or you can set it to a value below room temperature. 0 should work, if your room temp is above that...
Posted: Thu Jul 10, 2014 1:25 am
by jccdesign
ok i set the set point 1 0, and it worked
