M2 Frame Vibration Dampeners
Slipshine
Re: M2 Frame Vibration Dampeners
Post by Slipshine » Tue Aug 11, 2015 2:07 am
Sorry not the bungee.
movie.zip
Print video (dark)
(456.25 KiB) Downloaded 584 times
Slipshine
Post by Slipshine » Tue Aug 11, 2015 2:10 am
That brings up a point. Can you upload a video here.
Post by insta » Tue Aug 11, 2015 2:16 am
Nah put them on Youtube
pandelume
Post by pandelume » Tue Aug 11, 2015 7:28 pm
Perhaps we should consider replacing the stock M2 feet with something like this:
http://www.mcmaster.com/#9232k16/=yg9i4g
I'd think that the Z load capacity would be almost irrelevant for this use, so long as you're not bottomed out - what we're concerned with is acceleration loads in x and y. In the M2 stock configuration (assuming a more or less rigidly mounted frame) the only shock absorption for x and y direction changes are the X and Y drive belts - what little stretch they have - resulting in ringing artifacts in the print. By letting the frame float we allow some of that load to be absorbed in the frame vibration mounting instead of the drive belt, resulting in less ringing.
Or so I'd think, anyway. I'm not exactly sure if that was the OP's intent with the design; it sounds like maybe he was concerned with induced vibration in the table making it's way back to the printer - that may also be an issue, but I'd have guessed it takes a back seat to belt elasticity related ringing.
innkeeper
Post by innkeeper » Tue Aug 11, 2015 8:51 pm
i think you would have better results in reducing vibration transmission using something like this
http://www.aliexpress.com/item/Hifi-sto ... 41577.html
Bratag
Post by Bratag » Tue Aug 11, 2015 9:02 pm
I went for the ghetto solution when reducing vibration from printer -> table -> printer by using egg carton packing material strategically wedged between the printer and the table. Not ideal but it really cut down on shimmy when printing small infil.
innkeeper
Post by innkeeper » Tue Aug 11, 2015 9:38 pm
LOL, i had an instant image of a MB bolted into a sold concrete block... try and vibrate that :P
Slipshine
Post by Slipshine » Thu Aug 13, 2015 3:44 pm
innkeeper wrote:i think you would have better results in reducing vibration transmission using something like this
Man I haven't seen those for awhile. They could have a bearing. I know whey do a good job of taking table vibration and isolating it from the turntable.
Especially at loud volume.
I was trying to give the vibrations that get in to the frame from the platter someplace to go other than back to the platter.
These might work both ways. Let me know if you try it.
innkeeper
Post by innkeeper » Fri Aug 14, 2015 5:07 pm
fortunately or unfortunately, i have no test case for it.
i used dampeners on the steppers, made those supper quite, and the table it is on is extremely stable.
so nothing moves, and the PS fan is the loudest thing when printing.
i do happen to have some spikes laying around..they were for some speakers i got years ago.
