Newbie Makergear M2 Dual setup question
KD5RKO
Post by KD5RKO » Fri Jan 17, 2025 8:13 pm
So I got a Makergear M2 Dual which started life as a single and was then upgraded. I've gotten as far as getting the bed levelled and making a singular successful test print which was in the middle of the bed. When I tried something larger which goes to the edges, it goes off the bed. I'm using Octoprint on a Pi. When I go to home in Octoprint the nozzles are past the edges in both dimensions. (See picture) Is there a physical adjustment to the equipment I can make, or do I need to change the settings within Octoprint?
Thanks in advance for any assistance. I'm sure this is something super simple.
Also, when I get that squared away, I'm sure I will have to change the boundaries somehow to change the second nozzle?
Gwhite
Re: Newbie Makergear M2 Dual setup question
Post by Gwhite » Tue Jan 21, 2025 4:05 pm
As you have discovered, this forum is pretty quiet. Unfortunately, I have a single extruder machine and can't provide any assistance. Your best bet is probably to contact MakerGear factory Tech Support. They've always been helpful when I've had a question.
The other thing might be to track down the upgrade instructions for the dual extruder conversion. That might provide some insight into what is going on.
Good luck!
Post by airscapes » Thu Jan 23, 2025 11:29 pm
I was given a duel and the first thing I did was remove the addition components and make it a single.. I had the luxury to have been give all the original parts so it was not a big deal to revert to a single extruder
I do not think you can use the entire bed for a single print. this setup we more to make copies of small items..
